Switch Hardware and Software
how to work with gpib sriel polling procedure
Hi all,
 i try to communicate with a Black Body, i give him a define Temperatur via GPIB, and it all works when I using the Commands as a String and work with GPIB-REAd and GPIB-WRITE. But if i want to read the status if the temperatur is almost stabil or not the describtion say " use the serial polling procedure syntax" and i don't really know how to filtering te rigth byte to get this information.
I know that the third byte is the one I need and that it has to be ,1 but how?
Is it possible to get this information?
(6,272 Views)
I'd recommend posting in the correct forum for a quicker answer.
-John Sullivan
Problem Solver
(6,262 Views)
Ok i'll try an other forum Smiley Surprised
(6,252 Views)
