Switch Hardware and Software
niSwitch vs DAQmx
I am interested in a general discussion of the differences between DAQmx and niSwitch. DAQmx seems to be a superset (newer implementation?) of niSwitch.
When controlling a simple device such as a relay driver (PXI-2567), is there a reason to choose one of these over the other? Both have the ability to open and close switches.
Can I mix and match them in the same vi? I seem to remember hearing that I should stick to one switch control pallet in a given vi.
Are there programming situations where there is a compelling reason to choose one over the other?
Thanks in advance for the advice,
Bob
(6,798 Views)
Hi Bob,
Hopefully this Knowledge Base will answer your questions about the differences between NI-Switch and DAQmx for switch programming.
Jennifer O.
(6,781 Views)
