Switch Hardware and Software
relay control
Can I control Relay bank (customised) with DIO PCI card? if not, what else can i do?
(7,073 Views)
Hi PriyankaJ,
You can use a DIO PCI card to control a custom relay bank.  Relays controlled in this manner would likely be toggled open/closed via the digital states of the DIO card.
Here is a link to a DIO PCI card option, the NI PCI-6509:
https://www.ni.com/en-us/support/model.pci-6509.html
As an alternative, you can also use a relay driver module.  The NI PXI-2567 and the NI SCXI-1167 provide control for up to 64 external relays.  The benefits to using a relay driver module are the following:
  • High-power protection circuitry
  • IVI-compliant NI-SWITCH driver software (compatible with NI Switch Executive)
  • Provides up to 50 VDC or 600 mA per channel with an external supply
  • Includes connector and backshell for signal connections
Here is a link to the product page for the NI PXI-2567:
https://www.ni.com/en-us/shop/model/pxi-2567.html
Here is a link to the product page for the NI SCXI-1167:
https://www.ni.com/en-us/support/model.scxi-1167.html
Hope this helps!  Let me know if you have additional questions!
Chad Erickson
Switch Product Support Engineer
NI - USA
(7,071 Views)
