Switch Hardware and Software
switch executive 1.01 and MAX 4.1
Hi all,
I'm trying to install LabView 8.2, MAX 4.1 and Switch Executive 10.1 on one PC.
At one PC, where I constantly updated the versions, everything works fine.
On the new PC, I can not create new SE Devices in MAX.
The LabView VIs are functioning, SE is listed in MAX in "Software", but there just is no option to create a new SE Device.
What to do?
Thomas
(6,687 Views)
Hi Thomas,
I know you might have tried this already, but just to verify, in MAX have you right-clicked on Device and Interfaces and selected Create New...?  A window should appear and one of the options should be to create a NI Switch Executive Virtual Device, as shown in the attached picture.
If you're not getting this option, please attempt to uninstall and reinstall NI Switch Executive to see if that fixes the problem.
Hope this helps!
Chad Erickson
Switch Product Support Engineer
NI - USA
(6,671 Views)
