Switch Hardware and Software
teststand switch step without NISE software installe
Is it possible to run a sequence with switch steps on a PC without NISE installed. Is there a run time engine or something.
kph
(6,638 Views)
In order to access a NISE virtual device fom TS you will need to have the NISE virtual device present in MAX and therefore you will need at least the deployment version of NISE installed on the machine.
(6,635 Views)
