Sync Labs
FPGA Timekeeper 1.1b0.zip
(14,199 Views)
Known Issue - FPGA Timekeeper 1.1b0
The "LabVIEW Time to FPGA Time.vi" casts LabVIEW time to double precision floating point. This results in loss of precision when converting to FPGA time: NI TimeSync: FPGA Timekeeper 1.1b0 library precision error - NI Community
Attached "FPGA Timekeeper 1.1b1.zip" resolves this issue by using extended precision floating point numbers.
Note: The updated version of "LabVIEW Time to FPGA Time.vi" is saved in LabVIEW 2021.
(1,891 Views)
Hello Drich,
I have this topic to understand
I have 1 crio chassis (9045) and I want to manage acquisition of channels by this way
1)  fixed crio module channels acquired using DMA FPGA. channels read using FPGA IO node under FPGA target
2)  variable module channels acquired using DAQmx (temperatures, flow meters, force sensors). channels data read from DAQmxunder RealTime side
i'm able to manage acquisition from DMA and DAQmx in the same timed loop, but i need to understand how to synch timestamp information: I want to provide timestamp t0 that comes from DAQmx (DAQmx read waveform array n channels n samples) to samples of FPGA Channels
can I do it using FPGA Time keeper API to synch FPGA time to Realtime time?
best regards
Michele
(394 Views)
Hi Mchele,
The timekeeper won't really help you to sync your FPGA on the DAQmx clock.
However, what the FPGA timekeepr does is to get its original time from the RT controller. Then it keeps it and update it on the FPGA side.
Compared to the clock on the RT side, the clock on the FPGA side is way better and is less prone to shift.
So what you could do is get the time on the FPGA side and associated a FPGA timestamp to the FPGA data that you push inside your DMA.
You would then be able to align your DAQmx samples with your FPGA samples.
I've never used DAQmx on RT, so i don't know where the tiemstamp of the data comes from though. So there is a risk taht you might comapred time coming from 2 clocks that are shifting one from the other...
Maybe taking a look at TSN would help a bit better ?
TSN time is accessible from the FPGA. And I wonder if DAQmx on RT side is also disciplined by the TSN clock...
However with TSN you'd need a reference time clock (another cRIO for example or a master clock).
CLA, CTA, LV Champion
View Cyril Gambini's profile on LinkedIn
This post is made under CC BY 4.0 DEED licensing
(387 Views)
Hi Cyril,
Do you know if there is a way to synch the clock of DAQmx and the clock of FPGA?
I know something about TSN (used for PXI + cDAQs + NI PXI-6683H ) but now my sistem is only 1 chassis, I would like to setup an Hybrid acquisition DAQmx+FPGA
thank you a lot
Best regards
Michele
(378 Views)
Hi Michele,
Nope I don't know.
I actually never used DAQmx on RT. I always go the FPGA route for all my signals.
(369 Views)
Hi Cyril,
this is what I want to do! Now is clear
It is not timestamp synch what I need. I need DAQmx provide data only when FPGA provide data, so clock syncronization.
It solved  my request:
Solved: FPGA and DAQ card synchronization - NI Community
thank you!
(344 Views)
