Sync Labs
Source code for TimeSync for SNTP plugin
Hi all,
I was wondering if the source code for the TimeSync for SNTP plugin was available; In my team we are fighting with an issue that maybe we can work around if the libs were accessible.
Thank you so much for the attention!
(6,758 Views)
Hi crandiba,
Unfortunately, the source code for the TimeSync for SNTP plugin is not publicly available. However, if you could share some details on your team's end goal and the problem that you are currently fighting, then myself or other community members may be able to provide some insight!
Tom D.
Staff Software Engineer
NI
(6,729 Views)
Hi Tom,
Thanks for the quick reply; I'm discussing it with the team and I guess well'll make a new topic for the issue on the forum. Essentially, it might be an issue with another dll that makes use of the ws32 dll - which I suspect the plugin uses?
Thank you so much and to the community for all the support!
Cheers
(6,721 Views)
