SystemLink Forum
Automatic configuration of SystemLink client in TestStand deployment?
Hi.
I would like to make a complete installation of a TestStand deployment including the SystemLink Client on a freshly installed Windows 10 PC. With the new option in TestStand 2019 to make a package installer including all packages (also SystemLink Client), the installation part is easy enough.
But what I would like to know is if there is a way to have the SystemLink Client set it self up to connect to a predefined server?
In this way it would show up under "Pending Systems" in the SystemLink server right after the reboot, and it would be good to go as soon at I have approved it on the server.
Best regards
Jens Christian Andersen.
CLA, CTA, CPI
(3,609 Views)
https://forums.ni.com/t5/SystemLink/bootstrap-new-system-systemlink-client-bring-up/td-p/3804866
Did you read through this post? With a few batch files it seems doable.
(3,586 Views)
Accepted by topic author J.C._Andersen
If you plan to handle it at install time the easiest thing to do is include C:\ProgramData\National Instruments\salt\conf\minion.d\master.conf from a configured system in your package you plan to deploy.  When the system reboots after the install it will automatically try to connect to the server contained in that file.
Note you will still need to approve the target on the master before it can successfully connect and start publishing data.
(3,580 Views)
No I did not, thank you pointing me to that. I looks like I can use at least some of it.
Thank you Ryan.
Best regards
CLA, CTA, CPI
(3,572 Views)
Yes, I think that would be an acceptable solution.
Thanks JoshuaP.
Best regards
CLA, CTA, CPI
(3,568 Views)
