SystemLink Forum
Can't add feeds to a PC
I am running into an issue on one PC where I get an error dialog on Systemlink saying "The changes failed to apply" when trying to add feeds to a PC.
Here is an excerpt from the salt minion log file:
2019-05-16 11:21:21,574 [salt.transport.tcp:1015][ERROR ][3904] Got response for message_id 1 that we are not tracking
2019-05-16 11:22:20,260 [salt.transport.tcp:1015][ERROR ][3100] Got response for message_id 1 that we are not tracking
2019-05-16 11:23:18,620 [salt.transport.tcp:1015][ERROR ][4364] Got response for message_id 1 that we are not tracking
2019-05-16 11:24:17,094 [salt.transport.tcp:1015][ERROR ][11548] Got response for message_id 1 that we are not tracking
2019-05-16 11:36:42,886 [salt.minion :1918][WARNING ][11920] The minion failed to return the job information for job 20190516083633196095_6680. This is often due to the master being shut down or overloaded. If the master is running, consider increasing the worker_threads value.
2019-05-16 11:38:18,997 [salt.minion :1918][WARNING ][11920] The minion failed to return the job information for job 20190516083813688330_8908. This is often due to the master being shut down or overloaded. If the master is running, consider increasing the worker_threads value.
The whole file is mostly that "Got response for message_id..." message, but right at the end, around when i tried to add the feed is where I see the "The minion failed..." error.
Does anyone have any ideas what might be going wrong?
(3,453 Views)
What version of the SystemLink Server are you running? Also, are there other feeds already installed on the target you are trying to deploy to?
Brandon Grey
Certified LabVIEW Architect
(3,429 Views)
Is there a way to see what version of SystemLink Server is being used through the SystemLink Web Application?
(3,415 Views)
Not from the SystemLink Web App UI. You would need to open NIPM on the server to determine what version it's running.
Brandon Grey
(3,408 Views)
We are running Systemlink server version 18.2
(3,378 Views)
We’ve fixed a bunch of Systems Management Issues since 18.2. This sounds similar to others we saw. Are you able to upgrade to 19.0?
Brandon Grey
(3,372 Views)
