SystemLink Forum
Datafinder uninstall/install issue
I am using DataFinder Server 2017/2018 which is part of the SystemLink which is why I put it in this Product board.  I needed to revert DFSE from 2018 back to 2017 due to an issue with license  management.  I needed to uninstall 2018 DFSE and reinstall 2017.
On the first round of uninstalling 2018 and reinstalling 2017 I was getting:
NI Skyline Database Server 17.0 for Windows has failed.
NI File Service 17 for Windows 64-bit has failed.
NI RabbitMQ Configuration for Skyline Products has failed.
NI Skyline Service Manager 17.0 for Windows 64-bit has failed.
After uninstalling 2018 DFSE.  Not all the services were uninstalled.  So I stopped the affiliated services for each and removed the services manually via sc delete "service_name" in an elevated command shell.
After reboot and trying to install DFSE 2017 again one issue remained:
After much work with NI support it appears in my particular case the uninstaller did not clear out a registry key that seemed to be tripping up the installer.  NI support found a Google article https://groups.google.com/forum/#!topic/rabbitmq-users/68R7qRtboY4 that removed HKEY_LOCAL_MACHINE\SOFTWARE\Ericsson\Erlang\ErlSrv\1.1\RabbitMQ
I did the same but I removed the whole Erlang key.
Rebooted and reinstalled DFSE 2017 without issue.
Message 1 of 1
(2,788 Views)
