SystemLink Forum
How to change the server's health tag prefix?
My SystemLink server reports its health in tags like "localhost.Health.CPU.0.UsePercentage".
How do I change the prefix from "localhost" to something else (like "server")?
Certified LabVIEW Developer
(1,645 Views)
Currently that isn't something you can change, unless you modify the python code that is publishing it (not recommended).  Why do you want to change it?
We specifically set it to localhost to make it easier to build server health monitoring dashboards that will work on any server.
(1,622 Views)
Thanks for clarifying, Joshua. Supporting portable server dashboards makes sense.
I wanted to change it because the name "localhost" has a special meaning on a network related to loopbacks: (see 6.3.3 at https://tools.ietf.org/html/rfc6761 ). When I'm working from a client PC and I see a dashboard talk about "localhost CPU usage", I'd normally understand it to mean "my current PC's CPU usage" rather than "the server's CPU usage".
Since changing it is not supported, I'll make a note in my customer's documentation about the non-standard usage of "localhost".
(1,608 Views)
