SystemLink Forum
How to get the automated agent api key
Hi I want to send tags and TDMS files to my SystemLink server. I know there is an automated agent role within Systemlink server which can be used for this purpose. I want to use api key authentication but i cannot find the api key for the automated agent. How can i get access to the api key?
Message 1 of 10
(2,681 Views)
The SystemLink client uses the automated agent role. Once installed on your client machine and connected to the SystemLink server, you can use the Python or LabVIEW APIs to talk with the server through the SystemLink client's Automated Agent API Key.
What language do you use?
Santhosh
Soliton Technologies
Message 2 of 10
(2,664 Views)
Hi Santo,
I am using LabVIEW v20
Message 3 of 10
(2,662 Views)
Hi Santo,
I am using cRIOs connected to the systemLink server and need to add api key to send TDMS files and tags to SystemLink. How can i get the SystemLink client's Automated Agent API Key. If i leave the API key empty i get this error.
P.S. I have changed the URL
Message 4 of 10
(2,647 Views)
If the cRIO is connected to SystemLink, you can leave the `configuration` unwired.
Santhosh
Message 5 of 10
(2,636 Views)
I am getting the same error.
Message 6 of 10
(2,633 Views)
Accepted by topic author zombae
Okay, I overlooked the error, does your server have a proper SSL cert? try this one, wire only the Verify Server boolean to False, leave the rest unwired.
Santhosh
Message 7 of 10
(2,629 Views)
Hi Santo,
Yes it works now.
Thank you
But my question still is how can i get access to the Automated agent API key so i can use it systems not connected to my SystemLink server. Is the key automatically assigned when we connect using systemLink client.
Message 8 of 10
(2,621 Views)
@zombae wrote:
Hi Santo,
Yes it works now.
Thank you
Yes, it is generated only for the SystemLink Client only when connected to SystemLink server.
Is there a scenario where you cannot install SystemLink client to connect to the server and not username password based login for API access?
Santhosh
Message 9 of 10
(2,615 Views)
Hi Santo,
Our cRIOs have been having dropping connection to Systemlink server, we are investigating this but in the mean time i would like to use the API key auth process.
Message 10 of 10
(2,605 Views)
