SystemLink Forum
Pharlap Support Roadmap
Is there a plan for adding Pharlap support?  If so, is there a target release date?
(4,266 Views)
While Pharlap is currently not supported, we've seen customers be successful with dashboards, by publishing values from the RT PXI back to a host Windows PC that then publishes tag values up to the server.
I'm currently looking into what our official stance is on Pharlap. As far as I know, we haven't made any announcements about it.
Zofia
NI Technical Support Engineer
(4,233 Views)
Hi Inertia,
I've been looking into this, and your best bet is to contact us at NI directly. We don't have an official announcement about this, but would be willing to work with you and try to find a solution that will work for you.
Zofia
(4,191 Views)
We do not currently plan to add Pharlap support for systems management functions like software deployment or health monitoring.  Given platform limitations, we have not found an implementation option that would be superior to the RAD tool, and the development cost is quite high.
As was mentioned, you can write a LabVIEW application for a Pharlap target and send data to a SystemLink Server using the HTTP APIs.
(4,186 Views)
