SystemLink Forum
Populating Test results into SystemLink from CSV files using Python
I have a collection of CSV files saved to my SystemLink server that contain measurement data for various tests. I want to take the data from these CSVs and create test results on the server.
Is there a way to do this in Python without using TDMS/DataFinder? If so, which API would work best for this task?
Thanks in advance fine people.
(3,483 Views)
The API (systemlink.clients.nifile.models.upload_response module) should get you the uploaded file to python for further processing.
Refer: https:// <your  server address here> /niapis/python/modules/systemlink.clients.nifile.models.upload_response.html?#module-systemlink.clients.nifile.models.upload_response
Ajay
Ajay MV
(3,446 Views)
So, this example should get you started with querying for files on your server: https://github.com/ni/systemlink-server-examples/blob/master/jupyter/FileServiceExample.ipynb The example here should get you started with the APIs for creating tests: https://github.com/ni/systemlink-server-examples/blob/master/python/testmonitor/results/results.py
Cheers!
TJ G
(3,430 Views)
