SystemLink Forum
RabbitMQ database corruption
I first posted this at https://forums.ni.com/t5/SystemLink-EAR-Support-Community/Which-services-are-required-to-run-the-Sys..., but it nobody replied so I'm re-posting in case it was missed.
I was having trouble getting the NI Skyline Service Manager service up and running again. Every time I tried to start it, it would silently crash again within a minute.
It turns out that I was experiencing the same problem as the OP at https://groups.google.com/forum/#!topic/rabbitmq-users/sMubP52NfHs. Here's an excerpt from C:\ProgramData\RabbitMQ\log\rabbit@localhost.log
=INFO REPORT==== 20-Jul-2017::14:19:44 ===
Error description:
   {could_not_start,rabbit,
       {{badmatch,
            {error,
                {{{badmatch,
                      {error,
                          {not_a_dets_file,
                              "c:/PROGRA~3/RabbitMQ/db/RABBIT~3/recovery.dets"}}},
I had somehow ended up with a corrupted copy of C:\ProgramData\RabbitMQ\db\rabbit@localhost-mnesia\recovery.dets (it was 0 bytes). Each time I started NI Skyline Service Manager, it in turn tried to start the RabbitMQ service. However, RabbitMQ encountered the bad recovery.dets file and instantly crashed.
After I deleted recovery.dets, I was able to start the NI Skyline Service Manager again. As far as I can tell, my SystemLink is now working properly again.
This is a particularly tough issue, because the system fails silently, it persists between reboots, and needs to be resolved by modifying non-NI files. SystemLink would benefit from a troubleshooting tool that can detect and resolve this -- a good start would be a tool to scan the RabbitMQ logs to detect errors.
Certified LabVIEW Developer
(4,926 Views)
Thanks for the additional information.  We will look into creating a troubleshooting tool and specifically try to catch this issue and automatically fix it in a future release.
Can you think of anything that you may have done when installing the software that could have caused this issue?
(4,895 Views)
Great to hear, JoshuaP!
I'm not sure that the problem was introduced during installation, because after installation I was able to run the SystemLink server just fine.
However, Windows Automatic Updates decided to kick in soon after, and I had to reboot. It was after this reboot that I had trouble starting the SystemLink server.
According to the comments at https://groups.google.com/forum/#!topic/rabbitmq-users/sMubP52NfHs, it sounds like an improper shutdown can cause this particular issue.
(4,872 Views)
