SystemLink Forum
Skyline Test Monitor G API Parse Test Step Data bug
Hi All
The '\\TestMonitor\Test Step\Unflatten Data From JSON.vi' file has a bug in it, when multiple parameters are stored in the 'Data' field it will not parse all parameters. The 'match Pattern' function only looks for '{' and not for ',{' when multiple parameters are defined in the 'Data' field.
Coert
(2,637 Views)
Hi Coert,
Thank you for this feedback.
Could you send some example code where you experience this? Then we can try to replicate it at our end and see if we get the same result.
Best Regards,
Bill
Technical Support Engineer
(2,587 Views)
