SystemLink Forum
SqlDatabase option missing in Sever Configuration window
I am trying to connect to the Postgres through SystemLink. I am trying to follow the instructions on the NI website at https://www.ni.com/docs/en-US/bundle/systemlink/page/remote-postgres-databse.html. However, there is no SqlDatabase option in the Server Configuration window. It seems like this is something that is supposed to be present out-of-the-box.
Can you please let me know how to create or access the SqlDatabase option?
(2,394 Views)
It is only available if you are using SystemLink Server 2022 Q1 or higher and have the SystemLink Test Module installed. The other modules and services don't use PostgreSQL and older versions of SL Server used MongoDB for storing parametric data.
(2,366 Views)
