SystemLink Forum
SystemLink API, add Test Step Measurement (DBL case)
Does Somebody already experienced this problem?
I just want to add test a DBL measurement to SL through a LabVIEW program:
but in SystemLink, there's something weird, the value is changed.
the problem is coming from the previous VI: Add Test Step Measurement (DBL) from the SystemLink API.
Weird no?
(2,141 Views)
If you actually look at the numeric constant with the 17 digits of precision, the value of 2.4 becomes:
Kenny
(2,073 Views)
Hi, ok yes I figured out that, but I wrote 2.4, it should be 2.4000000000000000000000000000000000000000000000000000000
(2,064 Views)
