SystemLink Forum
SystemLink Dashboard WebPage- misalignment of controls and indicators
I created a dashboard in SystemLink. The controls and indicators on the dashboard (in play mode) are misaligned when I open it on a monitor with lower screen resolution. Is there a way to fix this issue?
Nikitha
(2,613 Views)
You can give the dashboard different layouts for different screen resolutions. You can do this by clicking on one of the blue segments above the panel in the dashboard editor. If you hover your cursor over that blue line, it will display the resolution that the segment you click will display.
Once you've selected another resolution, it should reshape the panel to reflect the resolution that you are now working with.
Brandon Grey
Certified LabVIEW Architect
(2,611 Views)
