SystemLink Forum
SystemLink Error -251251
I am new to the SystemLink. I am trying to implement it in my program and view the results on Test Monitor. When I run the program, I get an error as shown in the screenshot below. Surprisingly, when I copy pasted the systemLink code (excluding my own program) in a new vi, it is working fine. It is giving the error only when implemented with my program. What could be the possible reasons?
Thank you!
(2,952 Views)
I have no idea why your code would work in one application and not another on the same system.  Is your tester show to be connected to a SystemLink Server?
(2,848 Views)
Accepted by topic author ajinkya007
Hi Joshua,
It was showing disconnected. That was the problem. It is working fine now.
Thank you!
(2,830 Views)
