SystemLink Forum
Systemlink Node Properties
I'm evaluating Systemlink and I have a quick question.  In the SystemLink Client (and the Systems Manager), I can see my tester nodes.  However, they show Model Name and Serial Number as Unknown.  Is it possible to set these properties somehow?  We have a very strict configuration management in place, and I'd like to used the tester part number and serial number here to identify the tester...
(4,384 Views)
By default SystemLink tries to pull this information from the systems BIOS, however older and some low-cost PCs don't always program these attributes when the motherboard is being manufactured.
You can overwrite these settings on the target by adding the following attributes to the C:\ProgramData\National Instruments\salt\conf\grains text file.
productname: Model ABC
serialnumber: 123456
Then restart the target or restart the NI Salt Minion Windows service on the target.  They should automatically update on the server the next time it connects.
(4,340 Views)
Wow, great, thanks.  Worked like a charm 🙂
Another questions arises:  Is there an additional configuration file for the PC as an asset?  This information is for the system as a whole, but in the asset manager I can also see the PC as an asset itself, with funky things like "To be filled by O.E.M.".  Can this also be overwritten?  I tried changing the values in the registry, but that didn't really do the trick...
(4,322 Views)
Customizing the asset for the system is a bit more involved, however there are some registry keys that can be added.  Attached is a zip file with 3 registry keys to modify the vendor, model, and serial numbers that are reported by the NI System API.  You can edit them with a standard text editor before double-clicking on them to install them to the registry.
This will change how the "system" resource/asset shows up in MAX and SystemLink.
(4,311 Views)
You may also need to restart the NI Minion Agent Windows service after changing the registry keys.
(4,310 Views)
Here is a link for some additional information.
https://github.com/joshuaprewitt/systemlink-custom-system
(4,277 Views)
Sorry for the late reply.  Had to try it out right away.  It helped a lot...
(4,190 Views)
