SystemLink Forum
Viewing Parametric TestStand Data
The HTML that is recorded with a TestStand test report has all the data I'd like to examine including an additional result (which is a string: Test Frequency).
1) When displaying parametric data for a test result is it possible to use the "additional result" from TestStand to use as the X-axis label? Even though this data is in the HTML file it does not show up when you hover over the data point in the in the parametric data.
2) How do you make and save a query for:
   A) Specific Product Name
   B) <All Serial Numbers>
   C) Measurement Name ("Max Power")
   D) Additional Result ("Frequency")
   E) Date/Time Range
   F) "Pass" or "Fail"
(2,673 Views)
  1. Right now the TestStand plugin is only capturing the parameters of the step (inputs, outputs, measurements). As a workaround can you turn the test frequency into an input of the test step?
  2. There isn't currently a way to save a query in the parametric data viewer as a named search like the result views. You can however copy the URL to reproduce the state of the parametric data viewer. It is updated as you configure the tool. Below I reference "measurement filtering" a few times. It is the filtering you encounter by clicking the "+" in the top-right of the viewer to the right of the "Measurements" label. All measurement filtering is represented in the URL.
    1. Product name is not currently available. Can you use part number?
    2. All serial numbers would be the same as not including serial number in the measurement filtering.
    3. Measurement name is selectable after filtering steps.
    4. Additional Results are not currently logged. I would suggest turning it into an input if possible. This will give the best filtering experience.
    5. In the measurement filtering you can specify a date range by applying operators to the "StartedAt" field. Dates are in ISO 8601 format https://en.wikipedia.org/wiki/ISO_8601
    6. In the measurement filtering you can specify the step or result status.
(2,622 Views)
