SystemLink Forum
"All feeds failed to update" when trying to deploy packages to client
While trying to deploy a feeds from the server to a Windows 10 Client, I receive the error "All Feeds failed to Update" on going to the Available Feeds on the client (attached screenshot). The server configuration is set to Insecure Remote Access with a Server HTTP port 9090, with other configurations set to default. The following measures have already been taken to troubleshoot:
1. NI Skyline Service Manager has been restarted and SystemLink Server Configuration shows no issues. Screenshot attached.
2. RabbitMQ had been running into some authentication issues which was fixed with the solution from the following:
https://stackoverflow.com/questions/47893899/authentication-failed-rejected-by-the-remote-node-pleas...
However the error still seems to persist. There is no issue in connecting the client to the server. I can restart the client from the server side if required. Both server and client have internet access.
Message 1 of 1
(2,464 Views)
