SystemLink Forum
"ERROR code 56" when Download systemlink Files
Dear ALL,
     When I use labview API to download files which are at systemlink server, I got the error code 56.
The systemlink version is 19.5.   The file size is 23MB.
Anyone know how to fixed this problem.
(3,298 Views)
Hi kisyou,
does this error occur for any file being downloaded from the server or only for files of a certain size (timeout error)?
-Stefan
(3,244 Views)
Hi kisyou,
From the jpg you attached, it looks like the error message you get is a timeout.  How long does it take for the VI to return that error?  As Stefan asked, do you get the same error when you request a very small file, say only 20kB or 50kB?
Brad
(3,235 Views)
Accepted by topic author kisyou
Hi Stefan,
   The error is form "http-get vi"  . The defaut timeout is 10s.   When I modify the defaut value, the problem is solved.
I think the labview vi should be optimesd the systemlink download vi, then we can change it easily.
thanks again
(3,226 Views)
Dear Brad,
   if the file size is small, the timeout time 10s is enough. The problem is api, we can not change the timeout value by a easily way.
thanks.
(3,223 Views)
