SystemLink Forum
struggling calling skyline related assemblies
I installes SystemLink Server and SystemLink Client on my Windows 7 64 bit machine.
Now I'm struggling exeuting the EAR examples (e.g.SimpleTagManager.lvproj)  of Systemlink on LV
All examples are not able to load the related Skyline assembly like:
  • niskyline_tag.dll
  • niskyline_file.dll
I am curious if the assemblies are correctly installed or if there are some issues related to NI Package manager, where the systemlink client package was installed.
I appreciate any help
Kind regards,
Rupert
Message 1 of 15
(5,144 Views)
 Hi Rupert,
It sounds like something didn't get installed correctly. Have you tried just removing the SystemLink Client software from NI Package Manager and reinstalling it? When installing the SystemLink Client software, make sure that support for your LabVIEW version is selected as a component to install.
Brandon Grey
Certified LabVIEW Architect
Message 2 of 15
(5,039 Views)
I have had the same problem.  I have tried the following:
Uninstalled and reinstalled
Uninstalled and installed previous version
Uninstalled Package Manager and installed previous version
I have concluded that Skyline API is not getting installed.  I have looked for the library and it is not there and the example projects are no were to be found.  I tried to install dependencies under Package manager, but they do not show up as an option under Systemlink Client.
Is there an exe instead of going through packet manager?
Message 3 of 15
(4,724 Views)
You need to be very careful when uninstalling and reinstalling things with NI Package Manager.  If it tells you to reboot you REALLY should before doing something else.
Did you by any chance uninstall it, ignore the reboot and then install the new version?
On Windows if a file is locked because it is in use for any reason, the uninstallation just marks the file for deletion after the next reboot.  If you then ignore the reboot and proceed to install a different version, you can then run into a situation where when your final reboot removes your newly installed files.
Message 4 of 15
(4,719 Views)
I appreciate the input, but I am pretty sure I rebooted every time I was asked to.  If something did get glitched up, how do I fix it.  I am still confused why the Skyline components do not show up under Systemlink Client dependencies.  If they were there, I could just add them.
Message 5 of 15
(4,712 Views)
What version of the SystemLink Client and LabVIEW are you using? Different versions of the client support different versions of LabVIEW. Additionally, the API will only install when LabVIEW is installed first but it sounds like you've met that requirement.
Brandon Grey
Message 6 of 15
(4,708 Views)
I am running Labview 2018 (32bit) and Systemlink Client 18.2.
Message 7 of 15
(4,704 Views)
Package Manager seems to think Labview 2015 is installed instead of Labview 2018.  I say this because when I try to install or uninstall dependencies for SystemLink Client it only shows files for 2015.Capture.PNG
Message 8 of 15
(4,701 Views)
When you look in Package Manager, do you see an entry in the installed tab for LabVIEW 2018?
Brandon Grey
Message 9 of 15
(4,699 Views)
Yes, Labview 2018 is listed as installed.
Message 10 of 15
(4,695 Views)
