SystemLink Idea Exchange
Community Browser
Post an idea
jordankuehnsef
Currently you can assign a Workspace to a State, but it does not restrict that state to a specific Workspace, e.g. a device in Workspace A can see all States as available to apply even if the States are in Workspaces B or C.
benebelt1
Hey there:)
It would be great if it was possible to set the datatype of an optimized property manually, e.g. with a DropDown in the Data Type column.
Currently it is only possible to optimize a property automatically.
As far as I know this task can be done in code in HTTP but an easier no-code solution  would be great.
The need for the manual optimization is following issue:
If you have a property in your index which is supposed to have a numeric value in it but in 70% it has a "NOVALUE" or "" of the DataTypeString in it, it will automatically be optimized as a String. This way it is not possible for the DataFinder to find the actual values which are stored as a numeric value.
Thanks!
benebelt1
