SercoSteveB has created the following VI but has poorly commented/documented his work (not for the first time
). Which of the following most closely matches the functionality provided by the VI?
NOTE: All hidden cases of the Case Structure are shown below:
a) The VI records the average value for each pair of values in Numeric Array In.
b) The VI records the number of occurrences of each unique value in Numeric Array In.
c) The VI records the rolling total of values in Numeric Array In.
d) The VI records the sum of the odd values in Numeric Array In.
