The Daily CLAD
Community Browser
Re: Connector Pane
SercoSteveB
Active Participant
Consider the VI Connector Pane shown below. Which of the following statements is TRUE regarding the top left and top right terminals of the Pane?
a) The terminals are configured for Static Values
b) The terminals are configured for Dynamic Dispatch
c) The terminals are configured for Polymorphic Interpretation
d) The terminals have been shaded (badly) by Steve using the power of GIMP
Comments
nik35324
B
The methods Dynamic Dispatch  and static are interchangeable. Right-click on the method’s connector pane terminal and then choose the desired terminal behavior.
Choosing "Required" changes to static dispatch.
For dynamic dispatch behaviour choose "Dynamic Dispatch"
crossrulz
Knight of NI
B
MrStevenUND
That's new to me!  B.
crossrulz
Knight of NI
For those who do not know, the Static Dispatch and Dynamic Dispatch are used when using Object Oriented Programming (OOP).
CataM
NI Employee (retired)
Good to know.
SercoSteveB
Active Participant
Answer: B.  Nice one all.
To create a dynamic dispatch member VI, you must set one input terminal on the connector pane to Dynamic Dispatch Input (Required).
You can create dynamic dispatch output terminals by right-clicking an output from the connector pane and selecting This Connection Is»Dynamic Dispatch Output (Recommended) from the shortcut menu.
Although a dynamic dispatch member VI can have no more than one dynamic input, the VI can include multiple dynamic outputs.
