The Daily CLAD
Community Browser
Re: For loops - MIND BENDER!!!
SercoSteveB
Active Participant
Steve - Just for fun!!!
What is the value in Numeric Value Out after the following has executed?
a)    0
b)    1
c)    2
d)    3
Comments
RustyStrings
the inner loop will output 1 + the second from the bottom terminal this will be put at the top of the outer loop and sent in to the next iteration
1st iteration (outer loop)
0
1+1=2 (put at the top of next)
2
2nd iteration (outer loop)
2
0+1=1 (put at the top of next)
1
3rd iteration (outer loop)
1
2+1=3 (send out)
0
so the answer is D 3
swetha_sadula
ANswer:D
ashwinilele
0th iteration of outer loop
            Inner loop
           0.        1
0.        3.         2
1.        0.         3
2.        1.          1
1 St iteration of outer loop
          0.         1
2.       2.         4
3.       2.         2
1.       3.         2
2 nd iteration of outer loop
           0.         1
4.        3          3
2.        4.        3
2.        2.        4
So output is 3. Ans Is D .  Procedure is correct or not?
Abodorra
D
Andreas.Bernau
D
Andreas.Bernau
@RustyStings
I like your approach.
But in a real exam when I am  getting nervous I would not be able to think like this.
I need simple solutions, without thinking if possible;-)
@ashwinilele
Take a look at the values you take over from one iteration to the next iteration of outer loop. It should be just one value not tree values. I think your procedure is not correct:
First iteration of outer loop we have an input of 0, 1, 2 and an output of 2.
Resulting in the input values of the second iteration of outer loop: 2, 0, 1 (not 2, 3, 1) and an output of 1
Resulting in the input values of the third iteration of outer loop: 1,2,0 (not 4,2,2) and an output of 3.
I recognized you have the same solution 3.
So I am not sure maybe I completely misunderstood your approach....
sac0071
D
Lily2016
3
ersmt444
Image broken
skian
d
