The Daily CLAD
Community Browser
Re: VI Server
SercoSteveB
Active Participant
Which of the following options most closely describes VI Server?
a) VI Server is a set of functions that allows you to dynamically control front panel objects, VIs, and the LabVIEW environment.
b) VI Server is the version of the LabVIEW designed for remote deployment.
c) VI Server helps you programmatically generate, edit, and inspect LabVIEW code.
d) VI Server is a suite of tools for Microsoft Visual Studio designed to help engineers create test and measurement applications in .NET.
Comments
Mantesh
Ans: a) By using VI Server we can programmatically control the front panel objects, VIs, and LabVIEW environment.
StefanoFacchine
I do agree with mahantesh, the correct answer should be A.
YogeshShivarudrappa
Yes, even I go with mahantesh and StefanoFacchinetti
Ans is A.
mini09
Active Participant
A
SercoSteveB
Active Participant
Answer: A.  Nice one mahantesh, StefanoFacchinetti, YogeshShivarudrappa & gnshmrthy. mahantesh that looks like a copy and paste straight out of the LabVIEW Help, nice!!
ashwinilele
A
skian
A
