The Daily CLAD
Community Browser
Re: Wait & Wait Until Next Multiple Timers
SercoSteveB
Active Participant
The following VI is run.  Which of the following are possible values passed to 'Timer Values Out'?
a) {16188300, 16188456, 16188612, 16188768}
b) {16188300, 16188400, 16188500, 16188600}
c) {16188300, 16188356, 16188412, 16188468}
d) {16188300, 16188456, 16188512, 16188612}
Comments
StefanoFacchine
the correct answer should be b), since the second frame in the sequence structure contains a "wait until next ms multiple" function. Therefore, the VI monitors the clock and exits the frame every time the clock is a multiple of 100 so that the Timer Values Out can only end with ***100.
ahmelsayed
I agree with StefanoFacchinetti and the correct answer is b).
mini09
Active Participant
Yeah i`m also going with B.........
But when i run the code for many times the value changes , is there any function to reset the values of the function?
Ajay_MV
Active Participant
I agree with b.
Ajay MV
SercoSteveB
Active Participant
Answer: B.  Nice one StefanoFacchinetti, Ahmed Elsayed, gnshmrthy & AjayvigneshMV
Nice explanation Stefano, the "wait until next ms multiple" is the key.
mohamedtanveej17
Hi everyone
 Evertytime I'm run this code with wait and Wait next ms multiple with the value of 100 I will get some mismatch values ending with some fraction values such that 100,201,301,400
Is it is an error or it is acceptable values?
crossrulz
Knight of NI
With Windows, I would consider than an acceptable error.  Windows is not a deterministic OS, so the timing is not reliable.
