The Daily CLAD
Community Browser
Re: While Loops #3 - Auto Indexing Defaults
SercoSteveB
Active Participant
For and While loops have the capability to auto-index the contents of an array control or indicator wired to the structure boundary.  Which of the following are the default states for auto-indexing of For and While loops?
a)      For loop: auto-indexing disabled, While loop: auto-indexing disabled
b)      For loop: auto-indexing enabled, While loop: auto-indexing enabled
c)       For loop: auto-indexing disabled, While loop: auto-indexing enabled
d)      For loop: auto-indexing enabled, While loop: auto-indexing disabled
Comments
SercoSteveB
Active Participant
Answer 😧
The following VI Snippet shows the auto-indexing defaults for While and For loops.
I created the Numeric Array In (U8) array and wired it through the loops.
You can enable/disable auto-indexing from the right click shortcut menu of tunnels (looping structures only).  Auto-indexing can be enabled/disabled on input and output tunnels independently.
ashwinilele
D
