I think it is more complicated: LabVIEW 2014 help (via Internet) says: "Error I/O operates uniquely in this function, which closes the file regardless of whether an error occurred in a preceding operation."
But the point is we overwrite the error output of write file and open file. Let’s assume there was an error (no or not enough disk space, drive is read only, no permission or something else) we are not able to handle the error. So to be precise for this very seldom and special case I would prefer answer d. Even most likely in almost all other cases correct answer from one day before is correct. (But it was undefined too 😉
Even with an error, the file is still closed (I did not know this until looking at help)
There are a lot of functions that work even with an upstream error. These are mostly "Close" functions (which makes perfect sense to me). But always check the help to make sure.
Speaking of the help, here's a little paragraph that is in the help for the Format Into File:
This function converts new lines, or \n, in the format string into the platform-specific end-of-line character, for example, CR/LF on Windows, CR on Mac OS X, and LF on Linux. If you do not want to convert new lines into the end-of-line character, use the Format Into String function and wire the resulting string output to the text input of the Write to Text File function. Then right-click the Write to Text File function and remove the checkmark next to the Convert EOL shortcut menu item.
There are only two ways to tell somebody thanks: Kudos and Marked Solutions Unofficial Forum Rules and Guidelines "Not that we are sufficient in ourselves to claim anything as coming from us, but our sufficiency is from God" - 2 Corinthians 3:5
