Troubleshooting Hardware
Broken CAN Connector
The CAN connector on our roboRIO 1 has broken. The CAN L push button seems to not have a spring below it. It easily falls down when pushed and stays down, but can be brought back up with a thin screwdriver. The CAN H push button does not depress all the way when it is pushed. The CAN L piece that holds a wire appears retracted, while that piece on CAN H appears to be mostly extended. Is it possible to fix this?
(11,921 Views)
I've sent you a direct message to coordinate the repair.
(11,666 Views)
