Troubleshooting Hardware
CAN bus broken on otherwise working roborio
The push pin connector has broken off the High (yellow) CAN bus input.  Otherwise the roborio works.  Is there a way to get a replacement or get it repaired?
(1,269 Views)
I have the same issue with my RoboRIO. Could I also get a replacement?
(1,248 Views)
ankiewiczk, I've sent you a message and we can continue to discuss there 😃
discoduck, can you create a separate thread for your issue?  Ideally, you'd include the same CAN port image if it's the same issue so we can quickly check that and move forward
(1,230 Views)
