Troubleshooting Hardware
Cannot Format or Update RoboRio
We have a v1 RoboRio that will will only connect via USB in safe mode and then will not update or format. Several laptops have been tried and they were all able to update other working RoboRio's. The unit will return a ping on 172.22.11.2. Laptops have no special characters in the names. Antivirus/Malware turned off. Only one RoboRio connected. Driver station shows good communications.
Brian
(383 Views)
Hi
This is Diego with NI.
I wanted to thank you for sharing this information of the case, have you tried the steps mentioned as possible solutions?
have you seen any blinking pattern in the leds of the roborio?
(359 Views)
Hi Diego,
All of the steps mentioned have been tried multiple times on several laptops.
No pattern was noticed.
(353 Views)
Bump
(301 Views)
