Troubleshooting Hardware
Corrupted Firmware on roboRIO 1
I have a roboRIO 1 that has corrupted firmware and I have been unable to update the firmware or reimage the device using the 'roboRIO Imaging Tool'.
Steps taken:
- Ran imaging tool as admin
- Put RIO into safe mode using the reset button
- Turned off windows firewall
- Used another USB cable
- Tried on 3 different computers
We can still SSH into the device, the status light is green and we can successfully put the RIO into safe mode. At this point it sounds like the best option is to reset the device to factory settings. Is there a way to do this?
(1,993 Views)
When trying to reimage:
Image Update ResultImage Update Result
When trying to update firmware:
Firmware Update ResultFirmware Update Result
(1,974 Views)
Accepted by topic author gmiller1
I sent you a message with the recovery utility and instructions to give it a try.
(1,940 Views)
I have the same issue. Can you please send me information regarding firmware recovery as well, or perhaps post a link to some resources.
(1,645 Views)
@bakedPotatoLord  Please post new threads for separate issues.
For historical purposes -
the factory reset method is now documented here: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000kOHkCAM&l=en-US
(1,638 Views)
