Troubleshooting Hardware
Digital I/O Ports Not Working on RoboRio v2
Hello all,
I have a RoboRio v2 whose Digital I/O ports aren't working. It doesn't matter which port I use; my code is not able to detect a sensor input reading any of the ports.
I've tried multiple sensors that I know work with the same result. I've used this EXACT same code on two other RoboRios with the same sensor and everything works, so I believe I've narrowed the issue down to the ports on the Rio
Any help would be appreciated!
Sam
(437 Views)
Hi Sam2847,
I've sent you a direct message, please reply with the information requested.
Kind regards,
(403 Views)
