Troubleshooting Hardware
FRC Team 4976 - 2 RoboRIOs need replacement
I'm a mentor for FRC team 4976 requesting RMA for two roboRIOs I have.
  • First one is bricked and we're not able to revive it.
    • P/N : 155213E-01L
    • S/N : 305A534
  • Another had bad ethernet port.
    • P/N : 155213F-01L
    • S/N : 316B254
Please let me know if any additional information is required.
Thank You,
Pratik Mistry
Team 4976
Please advice if any additional information is required.
(1,603 Views)
Hi pratikmistry03,
I'm Matthew with NI. Thank you for posting on the forums.
Let's focus on the first one for a little bit, what behavior do you see on the unit? Do any of the lights come on when power is applied?
(Also, it is a roboRIO v2 - with an SD card?)
(1,574 Views)
Sorry for the longest delay. There was a change over and I could not find this forum.
On the bricked unit when powered ON;
POWER = SOLID GREEN
STATUS = SOLID FOR FEW SECONDS THEN STARTS BLINKING
RADIO = OFF
COMM = OFF
MODE = OFF
RSL = SOLID
Both of the above do not have an SD card slot.
Thank you,
Pratik Mistry
Team 4976
(1,358 Views)
My apologies for a further delay, I missed the notification this was replied to.
Can you try to reset the device to factory image following the steps documented here: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000kOHkCAM&l=en-US
(1,288 Views)
