Troubleshooting Hardware
Need Roborio Unrecoverable Error Image File
My team bricked a Roborio by unplugging it while reimaging.
I diagnosed the issue, and I cannot connect through SSH, as the password was changed to something unknown.
I need to reflash the Roborio manually though a USB drive with Roborio firmware.
I was reading though forums on here and it looks like you need a special 'support version' of the firmware to flash through the drive to the Roborio.
I don't need help diagnosing or other routes, I just need this 'special version' of the firmware.
If I can find this firmware online anywhere (FRC website/Forums/WPILib), please let me know, or if support needs to send it to me digitally, that works as well.
Thank you! 😄
~Phil
(1,790 Views)
I'll send you a message to talk through the details and getting the recovery file.
It's not a special version of the firmware, for what it's worth.  It's just another way to install the factory version of the firmware onto the roboRIO and reinstall the things that are broken.
(1,759 Views)
It looks like I lied.  You have PMs disabled so I cannot.  Can you send me a message with another way to contact you?
(1,755 Views)
My team is facing this same issue. Could you also PM me the same recovery instructions?
(1,730 Views)
You have PMs disabled.  Is it alright if I email you at the account listed on your forum profile?
(1,723 Views)
Yes ok by me. Thank you.
(1,715 Views)
Sent an email.  If the tool doesn't work, it'd be helpful to create a new thread so we can focus on your specific situation to help get you up and running 😃
(1,690 Views)
