Troubleshooting Hardware
Red Power Light
The Power Light on our RoboRio 2.0 is red. We have flashed the SD card and have run code on it. We checked for any metal in the ports, but we could not find anything.  We tried a different SD card and different power source. We removed all devices plugged in. We tested to make sure the power and ground were not shorted. We also checked the voltage on the DIO which was 5V.
Message 1 of 9
(2,165 Views)
If you're seeing a red power light, that's the roboRIO telling you it's detecting a shorted power rail.
The first step in troubleshooting I'd recommend here is to open up the driver station.  That should show you a red bar next to the lightning icon.  If you click that, I'd expect it'll tell you which rail it detects as shorted.  From there, we can focus efforts on cleaning up around that rail to make sure there isn't an issue.
Message 2 of 9
(2,131 Views)
It is on the 6V bus. I didn't see anything in the pins.
Message 3 of 9
(2,123 Views)
I'd expect that to mean the servo voltage at the end of the PWM ports.  Does anything look off here?
Message 4 of 9
(2,114 Views)
Nothing looks visually abnormal. We checked the voltage between power and ground and got 6V.
Message 5 of 9
(2,108 Views)
It is still showing a red light
Message 6 of 9
(2,081 Views)
we are at the exact  same situation...
meanwhile roborio can be reachable through web gui
Message 7 of 9
(2,022 Views)
"That should show you a red bar next to the lightning icon."
where is it ? can you describe
Message 8 of 9
(2,028 Views)
On the left side of the driver station, there are a few icons.  It would be there when you're connected to the RIO from your driver station.
If you have further questions, please create a thread specifically for your issue rather than continuing another thread.
jmarkesio, Are you still seeing your red power LED?
Message 9 of 9
(2,018 Views)
