Troubleshooting Hardware
RoboRIO 2.0 Unrecoverable Error
Hello! I am Jimmy a programmer from 9496 LYNK, at the FNC District UNC Asheville Event I got hit with an Unrecoverable Error on our RoboRIO 2.0.
We have tried:
  • Reseating the SD Card -> Same Error
  • Reflashing the SD Card -> Same Error
Any tips
Jimmy (9496 LYNK)
(625 Views)
Hi Jimmy,
Thank you for posting on the Forum. My name is Jessica, I'm with NI.
Can you try going into safe mode (press and hold reset button until status light is solid lit and then let go)?
Also, have you tried using a different SD Card?
(599 Views)
Yes I have tried both a new SD card, and going into safe mode. No dice.
(588 Views)
Hi Jimmy,
I've sent you a private message with next steps.
(562 Views)
