Troubleshooting Hardware
RoboRIO CAN connector
We have a NI roboRIO v1 and the upper CAN wire locking mechanism is broken. The wire just pulls right out. Can this me repaired or will be have to spend $485 to buy another?
(2,027 Views)
I sent you a message.  Let's handle a replacement there 😃
(1,880 Views)
Our CAN connector for the low side (GRN) no longer holds the wire. The little white tab does not spring back up, and the wire simply falls/bounces out. I was advised to come here for help in getting it repaired.
I am attaching pictures of the UL & S/N label, plus two images of the malfunctioning connector.
The connector is the only problem with this Roborio. Everything else functions properly.
please advise,
P. Laux
plaux@aisd.net
FRC team 3676
(1,745 Views)
In the future, please create a new thread.  Having multiple issues in the same space adds to confusion.
It looks like your CAN port is damaged.  Are you alright if I send you an email on the address associated with your forum account?
(1,739 Views)
Yes, yes you certainly may send me an email.
Sorry about not starting a new thread.... this is all very new to me.
Thank you for your response and help.
(1,733 Views)
