Troubleshooting Hardware
RoboRio 2.0 Stop Powering Up
We purchased one Nov 21, 2023. It was working fine but recently stopped powering up (i.e. power light is off). We swapped with our old RoboRio 2.0 and confirm the old one does work.
From another thread, we've tried: removing the SD card, inspecting the slot for metal shards (hold upside down and shake vigorously), then re-seat the card but has no luck.
We saw the following suggestion, should we try that next? Please kindly advise.
Open the device using the four screws on the back and the two screws at the port port and clean the unit off using compressed air. (Maybe also use a flashlight to inspect the board closely for any remaining metal shards and remove them as well.)
Message 1 of 9
(1,285 Views)
Hi
This is Diego from NI.
Yes, could you please try to perfor the steps Open the device using the four screws on the back and the two screws at the port port and clean the unit off using compressed air. (Maybe also use a flashlight to inspect the board closely for any remaining metal shards and remove them as well.)
Let us know if you had any success
Message 2 of 9
(1,244 Views)
Hi Diego,
We've tried that but no success. The board looks very clean.
Wai
Message 3 of 9
(1,223 Views)
Hi Diego,
Do you have any suggestion? Otherwise, can we ship it back for repair?
Thanks and Best Regards,
Wai
Message 4 of 9
(1,127 Views)
I've sent you a direct message to coordinate the repair
Message 5 of 9
(1,108 Views)
I've replied to the private message but hasn't gotten any reply. Just wondering if any information is needed from my side to proceed with the RMA?
Thanks!
Wai
Message 6 of 9
(1,007 Views)
Hi Wailau117, can you confirm that Diego has now followed up?
Message 7 of 9
(987 Views)
Hi mshafer,
Yes, he told me NI team is going to contact us on further steps for the repair and I just got an email of a Fedex package coming.
Message 8 of 9
(982 Views)
Hi mshafer, Diego,
I got the refurbished RoboRIO2.0. Thanks a lot!
Best Regards,
Wai
Message 9 of 9
(971 Views)
