Troubleshooting Hardware
RoboRio will not take code and can not image the RoboRIO, PN: 155213F-OIL sn: 31C254E
The RoboRIO that we used in 2023 competition  RoboRIO, PN: 155213F-OIL sn: 31C254E is not working. Can not download code. Tried to image the RoboRIO but did not image. Reset RoboRIO still same result.
Advise
I called NI and they sent me back to First forum.
Can I get a RMA number to return this unit?
Spencer Ruffner
ruffnersp@gmail.com
(517)215-9292
Team 3773
Tecumseh high school
Tecumseh, Michigan 49286
Message 1 of 8
(2,920 Views)
I'm Thays from technical support.
Could you let me know in which part of this guide, LabVIEW for FRC Shows Connection Failed to My roboRIO,the roboRIO stopped working?
Message 2 of 8
(2,885 Views)
Thays,
RoboRio will not image. We reset the roboRIO still will not format. Using current software tools FRC_roboRIO_2024.v2.zip image. Ran as administrator etc. We formatted other RoboRIOs okay.   RoboRIO did not image / formatRoboRIO did not image / format
Message 3 of 8
(2,852 Views)
Did you already follow the steps in this article Unable to Connect to roboRIO in Driver Station, Imaging Tool or LabVIEW - NI?
Message 4 of 8
(2,837 Views)
Yes followed all the steps in the imaging tool..
Message 5 of 8
(2,832 Views)
Status?
Message 6 of 8
(2,825 Views)
At Format target
Message 7 of 8
(2,807 Views)
Could you confirm if you make this steps, FRC roboRIO STATUS LED Constantly Flashing - NI, with several USBs and with a powered USB hub?
Also, are you using a roboRIO 1.0 or roboRIO 2.0?
Message 8 of 8
(2,791 Views)
