Troubleshooting Hardware
Roborio 6V Short
Hello, I have a RoboRio with a short on 6V.  Disassembly and inspection did not turn up anything obvious for the cause.  Can someone please help with troubleshooting or a hardware RMA?  Thanks much.
(1,296 Views)
Hello Team1339.
A short is almost always caused by a metal shaving getting between pins or inside the case. Did/would you try cleaning it with a can of compressed air to try to knock anything loose?
(1,255 Views)
Yes, we did try that. Not having schematics, it's somewhat difficult though to focus on target areas for the 6V circuit.
(1,240 Views)
The "relay" pins are the ones that use 6V, so I would suggest blasting the whole thing, and focusing there.
(1,234 Views)
Unless something changed, the relay ports use 5v. PWM center pin is 6 v, so that's where I'd concentrate.
(1,182 Views)
