Troubleshooting Hardware
SD Card Ejects from Port on RoboRio 2.0
Our RoboRio 2.0 will not retain the SD card causing a failure in boot for the RoboRio 2.0.  Once we stop pressing against SD, it will not remain seated and will eject out of the slot.  We have tried multiple times to get it to click in, but it flew out moments later.  Please advise us on the next steps and thanks for the support.
(7,415 Views)
Hi bjones22,
I hope you are doing well,
The easiest way to resolve your issue is to get a replacement roboRIO sent out. We do need some information to process this.
I'll send you a direct message to ask you for further information.
Thank you in advance!
(7,185 Views)
