Troubleshooting Hardware
Team 4828 Roborio 2.0 5V Rail Failure
Our Roborio has a failure on the 5V rail - seems to be shorted.  We tried online troubleshooting, like making sure cleaned out for metal shavings, etc.  Can't get working.
(885 Views)
Hi!, Thanks for posting on forums.
A short is almost always caused by a metal shaving getting between pins or inside the case. Did/would you try cleaning it with a can of compressed air to try to knock anything loose?
You can also try removing the four screws in the back to take the cover off to clean under it.
(859 Views)
