Troubleshooting Hardware
faulty roborio SD card
hello,
our team has encounter an issue with a roborio 2 unit the SD slot seems to be jammed and the sd card cant be inserted into the device
i have tried to open the unit up and clean the port and nothing seems to work
best regards,
(454 Views)
Hi Sycamore5614,
This is Juan Garcia from the technical support.
Just to confirm the problem with the slot, have you tried a different sdcard?
(430 Views)
hello juan,
yes we tried that and that didnt work sadly
(409 Views)
Hi Syca,
I have sent you a direct message with further steps.
Regards.
(402 Views)
