Troubleshooting Hardware
roboRIO 2.0 SD card retention problem
The retention mechanism in the SD card holder of our roboRIO 2.0 (P/N 133340B-01L, S/N 32D20EB) recently failed, such that the SD card is no longer held firmly in place. The card will fall out if the roboRIO is flipped upside down. We tried a couple of different cards (different brands) to see if there was variation but there was not.
We are not sure exactly when it happened. This roboRIO has experienced normal FRC usage in competition robots but nothing unusual. We only have two RIO 2.0's and need this back in service soon.
Team 2228
(276 Views)
If NI is monitoring this forum, we are requesting an RMA number for return of this roboRIO 2.0 for service.
Thank you,
Tim Heywood, Electrical Mentor
FRC Team 2228
(210 Views)
Hi!, thank you for posting on the forums. I'm Matthew with NI.
Thank you for replying back again to alert me that this thread has gone unanswered. I will follow up with the team to see why that happened.
I've sent you a direct message on next steps to resolve this issue.
(204 Views)
